Re: Stuck Farmall H
Posted by El Toro on October 03, 2005 at 04:02:09 from (64.12.117.13):
In Reply to: Stuck Farmall H posted by James.01 on October 02, 2005 at 17:26:42:
Transmission fluid is what I used. You need to let it soak with dextron or something similar.
If it doesn't budge by bumping the starter I would use a piece of 2X2 oak or maple and give it an attitude adjustment with a big hammer. Not too hard, you do not want to damage the block.
The sleeve may come out with the piston. This happened on a Farmall A and I used a torch to
hear the sleeve and the piston came out. I only needed the rods since I was putting in a new sleeve kit. Need to be patient too. Hal
Post a Followup
