Re: Final Drive
Posted by Red Dave on October 03, 2005 at 08:01:58 from (24.104.94.34):
In Reply to: Final Drive posted by 1942 on October 03, 2005 at 07:49:52:
Might be a bearing.
Might be a loose bolt that holds the rim to the wheel center too, I've had that happen too.
Either way, I wouldn't let it go too long. It's not too bad of a job to take the drive off and go through it. Might need access to a press to get the axle out of the big gear. Everything else should be do-able with normal hand tools.
Post a Followup
