Re: Farmall M Carb
Posted by RustyFarmall on October 03, 2005 at 08:48:59 from (199.120.81.194):
In Reply to: Re: Farmall M Carb posted by Charles Park on October 03, 2005 at 08:35:55:
Charles, the float drop should be set at 1 15/16 inches. This adjustment is made by carefully bending the small tab on the float that contacts the needle seat. This is one of the many things that really irritates me with some rebuild kits, the instruction sheet is very vague about the procedure to clean the carb, and some of the important information is not even mentioned, such as you have found out.
Post a Followup
