Re: td15 info
Posted by Janicholson on October 03, 2005 at 12:53:45 from (199.17.6.175):
In Reply to: Re: td15 info posted by ottis on October 03, 2005 at 12:13:22:
The Only TD I have torn into is an 18 so my data is skimpy. If the left track clutch is stuck, it may require the deck to be pulled to get at it. Depending on how long the unit was not run, there is a chance it will break free. If you run it the way it is, rope the Left clutch back so it is driving as though turning this places load on the clutch packs, and it may break loose. The transmission output drives a bevel gear and ring gear turning the power 90 degrees. The ring gear shaft extends on either side into a track clutch housing. The clutch is a multi disk unit about 14 inches in diameter. The ring gear shaft has couplings on the end that bolt together allowing the clutch shaft to be removed without splitting the case. The clutch housing is bolted to the bull pinion flange on the outboard side with a series of cap screws around the preimeter (8 of them I think) These bolts are removed and the band brake around each clutch is disconnected and moved sideways then (maybe)removed. A hoist is attached to a sling (and at least one bolt hole) to lift the clutch up and out. It weighs ~250 or more (that is a guess, but it is not to be done lifting by hand). The hardest part is removing all the components from the cover and getting it off of the finals.
A parts book is manditory, as is a repair manual. The clutch has a spring in it that compresses the disks that will send a Farmall M to the moon if let go by accident. A 60 ton press is requires to be safe during disassembly, and needed as well to put it together.
Good luck and let us know what the status is on the repair. They are not complex, just heavy.
JimN
Post a Followup
