Re: 300U stuck on wet paper Kleenex
Posted by JB2 on October 03, 2005 at 17:08:34 from (69.196.154.214):
In Reply to: 300U stuck on wet paper Kleenex posted by Joe Kimbriel on October 03, 2005 at 11:45:22:
Hi Joe, did you take the locking pin out of the hitch arm so when you lower the blade your not lifting the back wheels off the ground?
When you are using a 2pt attached implement such as plow, disk, harrow or blade the 2 pt locking pin should be out so that the hitch can float with the contour of the ground or anytime a rear wheel drops in a dpression in the ground it will spin as all the weight is transferred to the implement.
JB2
Post a Followup
