Re: Farmall 100 head troubles !!!!!
Posted by El Toro on October 04, 2005 at 04:54:59 from (205.188.117.73):
In Reply to: Re: Farmall 100 head troubles !!!!! posted by Andrew Z on October 03, 2005 at 18:22:36:
As CNKS has suggested, do not drive a screwdriver
in between the head and block. This would do serious damage to your head and block. I wouldn't use any heat either.
You need to insert a thin blade putty knife between the head and the gasket. You need to be patient, someone may have coated the head gasket with some permatex.
I have heard in some cases the engine was started to free a cylinder head. I've never used this.
Did you ever find antifreeze in your engine oil?
Hal
Post a Followup
