Re: Fan drive pulley removal
Posted by Nebraska Cowman on October 04, 2005 at 16:31:52 from (65.165.16.211):
In Reply to: Fan drive pulley removal posted by Mel in OR on October 04, 2005 at 16:16:43:
It is straight but they stick in hard. Heat helps, so does holding a hevy sledge under the shaft for support when you hit it. Use a punch nearly the same size as the pin and a big hammer. If it is mushroomed over, saw it off flush.
Post a Followup
