Re: M farmall Starting Problems
Posted by El Toro on October 05, 2005 at 04:12:05 from (64.12.117.13):
In Reply to: Re: M farmall Starting Problems posted by Josh Johnson on October 04, 2005 at 19:23:06:
To find TDC you need to remove No1 sparkplug near
the radiator. Have someone hand crank the engine while you hold your thumb over the plug hole. Once you feel compression against your thumb stop cranking and look for the notch in your damper pulley. My manual says to use the first notch, but it may only have one notch.
Keep cranking the engine slowly until the notch
in aligned with the pointer. This is TDC for No1 piston. You should have felt pressure against
your thumb when doing this.
Don't move the engine once it's at TDC and remove the distributor cap and see where the rotor is pointing. It should be pointing to No1 plug wire.
If it is your distributor is in time. If it is off gently remove the the distributor and position the metal tip end of the rotor at No1
Plug and reinstall the distr. make sure it's at
No1 after you reinstall before turning the engine.
Have you checked your plug wires they may be just crossed. No1 plug wire should be at 1 o'clock on the cap and going CW the next wire should go to No3, then 4 and 2. No1 plug is near the rad and
No4 is at the rear of the engine. Hal
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
