Re: Engine cylinder numbering
Posted by El Toro on October 05, 2005 at 04:34:03 from (64.12.117.13):
In Reply to: Engine cylinder numbering posted by back to front front to ba on October 04, 2005 at 18:01:09:
On a 4 cylinder engine you can use No4 piston at TDC to install your distr or mag, but it's still at the rear of the engine and you would have to
install the distr or mag with the rotor at No4
plug wire. Never seen an engine from this country that numbers from the flywheel and that goes back 55 years for me when I was a teen.
Of course if you're referring to 1 cylinder engines that would be correct. Hal
Post a Followup
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
