Re: Hydraulics on 340
Posted by Wayne Johnson on October 05, 2005 at 15:44:43 from (204.249.66.195):
In Reply to: Re: Hydraulics on 340 posted by K.B.-826 on October 04, 2005 at 19:59:38:
From the book I have it does not have the Tel-a- Dept set up. The lift control lever on your right goes direct to the valve body. There is no other linkage to the lift system. On my left there is a lever you can raise or lower, but it doesn't connect to the hydraulics that I can see. It doesn't matter what position the hydraulics are in- All up- all down or in between. If they are not moving, the engine loads down from the pressure by not passing.I really do want to thank you for all your help. Any idea what to do next, Wayne
Post a Followup
