Re: Now that I've done it.....
Posted by Haas on October 05, 2005 at 18:07:21 from (12.65.6.70):
In Reply to: Now that I've done it..... posted by Superdave57 on October 04, 2005 at 17:25:43:
Only two reasons I can think of for using square head bolts.
1. You want your tractor to be as orginal as possible.
2. Sometimes the setting for the bolts have a recess ot a lug designed to accept square head bolts. The recess or the lug is to keep the bolt from turning as you tighten or loosen it. In this situation, nearly impossible to get a wrench on the head if you substitute hex bolts, so best to use the square head bolts.
Post a Followup
