Re: 460 gas guage sending unit
Posted by John T on October 06, 2005 at 06:43:12 from (66.244.90.98):
In Reply to: 460 gas guage sending unit posted by Steve 200460 on October 06, 2005 at 02:46:57:
Steve, I guess youre fer sure its a sending unit problem (usually is) and not the gauge??? If the gauge has voltage to its input (usually turns hot when ignition switched ON) and you take the output and totally disconnest it then ground it and that makes it full deflect from FULL to EMPTY etc. its likely good, and the problem is indeed a faulty sender as you suspect.
Ive also had problems where the sender isnt getting a good case ground (like from the tank or else its own lil grounding pigtail terminal) and conversely where the wire down to the sender is shorted out making the gauge stay constant.
John T
Post a Followup
