O/T for Dave in CT V belt Cment Mixer
Posted by Janicholson on October 06, 2005 at 13:06:06 from (199.17.6.69):
Dear Dave,
Our very old mixer originally had a water cooled single slow speed gas engine on it. It was replaced at some point before we got it with an old Westinghouse electric motor of about 3/4 hp (it draws about 8 amps when running loaded. The motor has about a 5:1 reduction from 1275 to 255 rpm. The V pulley on the motor is is about 6" in dia. and 5/8 wide. The pulley on the mixer is about 12 diameter and 2-1/2 wide. 2:1 ratio now 127 RPM. It has approximately a 10:1 bevel gear on the mixer resulting in about 12.7 rpm on the drum. These are best guesses as I am not near the mixer to check for real.
JimN
Post a Followup
