Re: PPG Omni 170 epoxy primer - temp question
Posted by CNKS on October 06, 2005 at 18:39:48 from (204.249.178.138):
In Reply to: PPG Omni 170 epoxy primer - temp question posted by Dave in CT on October 06, 2005 at 15:44:31:
While the "rules" for primer may be more lax than for topcoat, I wouldn't change anything. You might be able to go down to 60 degrees, I wouldn't go lower than 65, and prefer 70. Rule of thumb is to keep the temperature up during the drying process -- I do not know for sure what "up" means. I would guess you are ok at 60 or above. Might work at 50 if that's what the paper says, but I would not want to do that. The link indicates that it is dry in 30 minutes, so you probably don't have to worry about it. Ask Rod(NH) on the paint forum -- he knows more than I do.
Post a Followup
