Re: Output of H Generator
Posted by John T on October 08, 2005 at 20:48:18 from (66.244.90.98):
In Reply to: Re: Output of H Generator posted by '52 Farmall H on October 08, 2005 at 19:11:32:
I like things original myself, but when I use 6 volts I try n use 00 Gauge Battery n Starter n Ground cables and a heavy duty rated big battery all of which helps cold weather starting fer sure. Remember the Gen will put out max if the Field is dead grounded versus a resistive ground such as some of the light switches used for the low charge (lights off) position.
John T
Post a Followup
