Re: Farmall A mag timing
Posted by Paul in Mich on October 09, 2005 at 18:59:25 from (207.200.116.203):
In Reply to: Re: Farmall A mag timing posted by MACE on October 08, 2005 at 18:26:55:
Mace, You are pretty close to having it correct. Those engines and the ignition systems are pretty forgiving, in that it has to be radically out of time before any noticable difference. The correct timing proceedure is to pull the coil wire and hand crank or rotate the engine until #1 piston is at TDC on compression stroke. Verify the position with the timing mark on the fly wheel. Sometimes that is hard to find due to dirt and rust, but it is there, and can be lined up with the pointer. Next, remove the 4 wire mag cap and verify the position of the rotor to the #1 wire. That should be somewhere about 1:00. If the mag has not clicked, then loosen the mag and rotate the top of the mag toward the engine block (CCW if facing from the rear), then very slowly rotate the top of the mag away from the engine block (CW) until it clicks. YOu are then in time. If the mag clicks before you reach teh TDC timing mark, loosen the mag and rotate toward the engine (CCW) then turn the engine over until you reach TDC compression stroke, then rotate the mag away from the engine until it clicks. That is the position where you will obtain maximum power even though there is a wide latitude where it will sound fine. I know that this doesn"t sound very High Tech, but those engines weren"t meant to fit into the high tech arena, but were designed to be worked on by the most average of mechanic.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
