Re: Farmall C radiator problem
Posted by Jeff Olson on October 10, 2005 at 11:26:32 from (64.71.64.21):
In Reply to: Re: Farmall C radiator problem posted by 1031D on October 10, 2005 at 06:24:32:
These tractors came with or with out a water pump, the head gasket is different for those with water pump than those with out. If your tractor does not have a water pump it could be the head gasket.
Post a Followup
