Farmall A wheels rims and tires
Posted by MACE on October 11, 2005 at 18:27:55 from (66.23.231.163):
Just got the ole A running <-----excited about that.
Question,
I have been looking at rims and tire sizes. I seem to lean toward a slightly big diameter tire for the back. My opinion is the A just looks better with a little bit bigger tire. But what should I put on the back of this Farmall A size-wize. I see 8x24's and 9 x 24's and 11.2 x 24's and my A has a set of 12 x24's on it now. I think they look good, but would like it to have a wheel that is a little more original than what it has now. Is there a good place to by rims and tires from. I have one original stamped wheel that is in good shape for the left and I understand I may need a cast wheel for the right. Feel free to throw your opinions my way.
Thanks,
MACE
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
