Re: Novice needs help with a Farmall H.
Posted by farmallhal on October 12, 2005 at 10:18:57 from (64.24.35.17):
In Reply to: Novice needs help with a Farmall H. posted by Brad from PA on October 12, 2005 at 09:53:13:
Brad, there is a kill/on-off switch which you must pull out to provide battery power to the coil so it will start. It is located on the right side of the steering post down low and on the support casting for the belly hydraulic pump control rod. If it is an original switch it will say "pull to run and push to stop" on the knob. If it is no longer original a switch could be anywhere and of any type. If the starter just does not energize any longer it can be several things. Could be a bad connection at the starter cable at the switch, starter motor or battery. Could be the starter is locked up with the ring gear on the flywheel in which case you need to remove the starter mounting bolts and jiggle the starter motor so the starter drive can free up and retract. You already have a post which goes into the possible flood condition and could very well be the case if it was cranked some time which the switch in the off position. All of my three Farmalls have a uniquely different starting set up with use a choke, position of the throttle, etc. Find that on-off switch before doing anything else and it should start if the starter is free. Good luck and enjoy you Farmall moment. Hal
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
