Re: Novice needs help with a Farmall H.
Posted by Nat on October 12, 2005 at 12:38:22 from (64.80.110.22):
In Reply to: Novice needs help with a Farmall H. posted by Brad from PA on October 12, 2005 at 09:53:13:
There's no real trick to it. If the tractor is tuned up, all you need to do is pull out the ignition switch, advance the throttle a little, and hit the starter button.
Most require a quick blip of choke at the right time to get it to fire, then careful feathering of the choke to keep the engine running until it warms up a little.
When you hit the starter button now with the lights on, do they dim? If not, the starter button contacts have gotten burned, and aren't making a connection anymore. If the battery is dead, the lights will go out completely when you hit the button.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
