Re: Novice needs help with a Farmall H.
Posted by Brad from PA on October 12, 2005 at 13:34:12 from (164.156.5.162):
In Reply to: Novice needs help with a Farmall H. posted by Brad from PA on October 12, 2005 at 09:53:13:
Thanks everyone for your replies - I appreciate it! I think I found the main problem - the on-off ignition switch on the right side of the steering column is unmarked, and I mistook it for a choke! So, I started with it out, and then put it in thinking I was releasing the choke but in actuality killing the ignition - and from what some of you mentioned, flooding the engine in the process! Now my only question is this (and forgive me if it is a dumb one): where is the choke actually located? Thanks again; I can not wait to drive it!
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
