Re: 46 farmall h oil pressure
Posted by Slappy on October 13, 2005 at 02:56:28 from (143.88.85.82):
In Reply to: Re: 46 farmall h oil pressure posted by walter on October 12, 2005 at 19:41:05:
Yes, bad cam bearings will give you low pressure, but I think I would do two simple fixes first. Make sure your oil gauge is good. If so, check the oil pump a little further before tearing the engine down again. First, and I'm not trying to be a smart a** here, check the pump cover gasket. If you replaced it by making a new gasket out of regular gasket material you will have too much clearance between the cover and the gears and your oil pressure will be nill. The correct gasket is only 0.05" thick. If your good with the gasket, next I would check the clearance on the oil pump gears, both between the body and the gears and lash between the gears. If they are out of spec, put new gears in (NOS gears are available). Also be sure that the shaft does not have any side play, if it does, you need a different pump body and/or the shaft is worn excessively. Finally, (and this the the easiest fix) be sure that the gear end play isn't excessive as it will cut away at the pump cover. This happens a lot and causes oil to bypsss gears reducing pressure. If you find galling on the cover, measure the play between the pump body and the oil pump cam drive gear (write it down) if out of spec, knock out the pin, remove the woodruff key and pull the cam drive gear. Add shims (McMaster and Carr has them)to get the end play back into spec. Next have the pump cover milled flat, or if you have nothing but time on your hands, get a piece of plate glass, some grinding compound and do it yourself. Finally order a new gasket and reassemble. Despite the fact that the pump is bathed in oil they do wear. I bougt three used pumps before I found a good pump body, and all had gears out of spec. I replace the gears, got the end play into spec and put it in my rebuilt H - oil pressure shot to 70 psi and hardly moves. Once you know the pump is good, and the problem persists, it's time to think about the cam bearings. Good luck
Home
| Forums
Today's Featured Article -
Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
