Re: F-20 Hyd Pump
Posted by Delbert from Lincoln on October 13, 2005 at 08:18:01 from (152.163.101.13):
In Reply to: Re: F-20 Hyd Pump posted by JRD(VA) on October 13, 2005 at 07:53:19:
In the late 1940"s, between high school and the war in Korea, I worked for the home town hardware store which like many such small towns, had a IHC dealership. I have installed several of these pumps on F-20"s and F-30"s. The way I rember it, we used a M Farmall lift all pump, the pump coupler from a M, took a nut off the front of the PTO shaft, and screwed on The coupler nut for a M. We had a bracket made out of angle irons and flat iron, welded together and holes drilled in the proper places. It was the patern. Could not use it or sell it. Made one like it to hang the pump under the belly of the tractor. Sure beat lifting the cultivator with those two levers on the axle housings.
Post a Followup
