Re: tractor under water
Posted by Bill46 on October 13, 2005 at 09:52:18 from (63.65.68.246):
In Reply to: tractor under water posted by Treg on October 13, 2005 at 07:47:54:
Treg, do not forget the transmission and gear reductions. They have oil too...and if they went under more than likely have water in them too.
Bottom like, if something has oil or grease in it...drain, flush, drain and keep doing it until clean oil/grease comes out.
Once you have gotten all the water out or what you think is all out, run it a few times then do it all over again.
Don't take short cuts until you you can run/drive it for a few hours and everything looks good.
Had a friend drop one thru the ice when we were pulling logs years ago. He took short cuts and ended up replacing every bearing in the transmission and gear reductions.
Better to be a little on the safe side.
My 2 cents....
Post a Followup
