Re: Draining early M coolent for winter
Posted by El Toro on October 13, 2005 at 18:47:48 from (205.188.117.73):
In Reply to: Re: Draining early M coolent for winter posted by RustyFarmall on October 13, 2005 at 17:20:51:
That sure is weird, What size is that plug? If that plug can't be removed, is it big enough to drill a 1/4" hole through the plug to allow the block to drain. Then drill the plug with a "R" drill and then use a 1/8 pipe tap to cut threads
into the drilled hole so it can be plugged or install a drain cock. If this isn't possible
he may be better off to drain the radiator and antifreeze the tractor to keep it from freezing over the winter. Hal
Post a Followup
