Re: bucket lift issues
Posted by riverbend on October 14, 2005 at 06:17:35 from (208.160.34.39):
In Reply to: Re: bucket lift issues posted by Travis Conley on October 14, 2005 at 03:07:50:
I like mine on paper. That way, I can take it with me.
The fill plug, drain plug, and screen are all on the left side of the reservoir. You will have to remove the steering shaft to get the screen out to clean it. It won't hurt to get some of the crud off the bottom of the reservoir and flush out the old fluid - hoses, cylinders, etc.
Depending on what equipment you have, it will take between ~7 and ~10 pints to refill. Fill the reservoir to 1/2" of the filler opening. Operate the lift 10-12 times (leave the levers in the back position) and recheck the level. Manual says to use IH Touch Control Fluid. I have been using regular hydraulic oil.
Post a Followup
