Re: W400 gas, fresh OH won't run?
Posted by Nebraska Cowman on October 15, 2005 at 03:42:50 from (65.165.16.211):
In Reply to: W400 gas, fresh OH won't run? posted by WarrenBinKY on October 15, 2005 at 01:09:48:
I think you found your own trouble. It is not getting fuel. take the plug out off the bottom of the carb and see if fuel runs out then trace or correct acordingly. You won't be the first guy that had to take a carb apart the 2nd or 3rd time to get it right.
Post a Followup
