Re: SMD Won't start on gas
Posted by Janicholson on October 16, 2005 at 10:02:22 from (66.173.50.28):
In Reply to: SMD Won't start on gas posted by BLB on October 16, 2005 at 09:24:32:
The Third Valve in the cyilined head may not be opening (it is the only thing you didn't mention)
there is linkage on the outside of the head that moves a cam on the inside.
How did you start it on Diesel? They usually won't with the starter, the starter won't spin it.
If it is the same difficulty turning the engine when trying to start it on gas as when on diesel, I'd suspect this system.
They normally start like an gas M on gas. Meaning very easily little choke and just a few turns.
JimN
Post a Followup
