Re: swapping narrow to wide front on M
Posted by Geoff NY on October 16, 2005 at 10:34:06 from (24.185.231.211):
In Reply to: swapping narrow to wide front on M posted by KX on October 16, 2005 at 05:59:55:
The rear hole on the plate are what the axel bolts to. The plate is just an adapter to move the axel rearward. One set should be tapped and one set bolts through. If you want to cut a hole for the radiator drain or cap it. Make sure the radiator is bolted to the frame (you can"t get to the bolts with the adapter plate installed).
Post a Followup
