Re: H shift lever
Posted by Slappy on October 17, 2005 at 03:02:16 from (143.88.85.82):
In Reply to: H shift lever posted by Jay (ND) on October 16, 2005 at 14:12:28:
The hole caps you need are available for your CNH dealer - about $1.25 each. I tried unsuccessfully to get them from the auto parts stores (4) in my area and no one has plugs that small.
When I got it, my H had the exact problem you describe. I took a washer and filed the inside out to the correct size and the marked the outer diameter from the spring and shaped it with a bench grinder and file. You can secure it as CNKS suggests with a roll pin or (as I did) use a cotter pin. Put a little paint on it and no one knows the difference.
Post a Followup
