Re: My tune up went down hill. 1945 Farmall A
Posted by El Toro on October 17, 2005 at 03:49:58 from (152.163.101.13):
In Reply to: My tune up went down hill. 1945 Farmall A posted by Philip in Maine on October 15, 2005 at 13:24:58:
Is this a magneto or distributor? If it's a mag
it will have an impulse coupling. The coil on the mag is installed internally within the mag,
with a distributor the coil would be mounted externally and would have the coil wire from the coil installed in the center of the distr. cap.
Since it ran before installing new points, I would reinstall the old points. .013" for a mag
and .020" for a distr. If this is mag, did you remove the mag from the engine? Hal
Post a Followup
