Farmall Cub Problem
Posted by Hpoor on October 17, 2005 at 05:31:06 from (64.48.129.73):
I took a cub apart about 3 years ago, worked on it for awhile and an just now getting back to it. i had already put one differential back together (short side) and now i am putting the offset side together after a long period of time in between.
the brake drum where it sits over the woodruff key that keeps it in place is really loose, the shaft is smaller in diameter than the inside of the brake drum. and the shaft with the key turn inside the drum, no matter how much the set screw is tightened. it looks like perhaps it sheared the key at one time??? and spun on there, but surely not that much? am i putting it together wrong or is it in need of replacing? anyone got a good breakdown of this setup? any help greatly appreciated. thanks!!!
Post a Followup
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
