FYI- 826 Fuel Sender - Found Compatible Aftermarke
Posted by Jim Allen on October 17, 2005 at 06:06:40 from (209.173.160.22):
FYI! While diagnosing an inop fuel gauge on
my 826D, I inadvertantly found an aftermarket
fuel sending unit that will work. It's AutoMeter's
(do a Google on Autometer gauges) part
number 3262. It has the exact same mounting
holes as the orignal and the same 33-240
ohm range. It's a univerasal setup so you can
adjust the arm to be exactly like the IH unit.
Should be a bolt-in. I don't know if the
Autometer is cheaper or more expensive than
an original IH part (if available from IH still). I
had it leftover from a project vehicle and used
it for tests. It's too bad that it's my gauge that's
bad, though.
Post a Followup
