Re: IH 684 water in oil
Posted by CEB on October 17, 2005 at 07:59:05 from (199.150.177.135):
In Reply to: IH 684 water in oil posted by Stuart Walker on October 17, 2005 at 07:28:10:
Its too bad that you removed the head, now you will have to take some extra steps to see if the sleeve O-rings are leaking. You will have to put the old head gasket back on and torque the head down to spec's. Then get a radiator pressurizer (you could probably get one at an auto parts store). Remove the oil pan and install the pressure tester in place of the radiator cap and pump it up to normal operating PSI (usually says PSI on the radiator cap). If you have bad sleeve O-ring, you will see it dripping antifreeze. Hopefully, a sleeve O-ring is the problem, since a cracked head or worse yet, a cracked block will run into more $$.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
