Re: Brining a Famall M out of storage--Questions.
Posted by Delbert on October 17, 2005 at 17:35:39 from (65.164.58.48):
In Reply to: Brining a Famall M out of storage--Questions. posted by Blue3992 on October 17, 2005 at 16:01:10:
I would use whatever you use in your car and pickup. I have a M and a super H that i use 10w30 in year around. Don,t use them much so works for me. Maybe if you were going to plow or disc with it where you would pull it hard all day then might go to 30 weight. But not sure i would then even don,t think it would hurt much. Only thing after setting that long might want change oil after using it a few days. Most say it takes 8 quarts when changeing the filter i always put in 9 quarts with filter change that,s what the old guy,s all told me when i was a kid i,m almost 61 now been around farmalls all my life.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
