Re: stronger SuperA front end?
Posted by gene bender on October 19, 2005 at 03:41:30 from (66.43.221.118):
In Reply to: stronger SuperA front end? posted by flem on October 18, 2005 at 09:53:30:
You must not be locking the tie rod with the bolt in the slot or you wouldnt be getting out of alignment. The square heavy duty one uses the same tie rod assy so that wont cure the problems. Better check the movable end on each tie rod to see why they wont lock when the bolt and clamp are tightened.
Post a Followup
