Re: Starting to restore Super M
Posted by El Toro on October 19, 2005 at 07:30:16 from (205.188.117.73):
In Reply to: Starting to restore Super M posted by Farm-all-the-way on October 18, 2005 at 20:30:21:
What's wrong with the crankshaft? If it isn't broken and has enough metal in the bearing jounals
it can be polished or ground undersize. A good auto machine shop would be able to give some good advice as to what your shaft needs or if it needs to be replaced.
That engine block should be degreased and have new cam bearings installed. This is so you have good oil pressure. You need close tolerances on the rod and main bearings too. Valve guides
should be checked for wear too and replaced if needed. Any valve that is too thin should be replaced too. Hal
Post a Followup
