Re: Removing injection pump on a MD
Posted by Ron in Nebr on October 19, 2005 at 13:25:07 from (65.172.143.57):
In Reply to: Removing injection pump on a MD posted by Brad in WI on October 19, 2005 at 10:35:02:
I pulled the pump off my 650D and it should be similar.... Once all the fuel lines, linkages, etc. are off, get the motor to TDC on #1. On mine there was a groove on the crankshaft pully and a pointer so that part was easy. There should be a stamped steel cover in front of the pump. Remove that and notice the position of where the gears are. Wipe any oil off of them that may be there. There should be three bolts holding the drive gear on and a "pointer" that goes to degree marks on the gear. These three bolts go through slotted holes in the gear, allowing you to adjust pump timing. Take note of where that pointer is pointed. On mine there was a chisel mark(from the factory) on the pump hub that the drive gear bolts to. The chisel mark lines up with a mark on the gear if I remember right. Also I think there were punch marks(again from the factory) on both the drive and driven gears. These should all be lined up at TDC#1. If your memory is like mine, take the time to grab a peice of paper and sketch out the gears and where all the marks are. Unbolt the gear from the pump and unbolt the pump from the engine and it's ready to come off. The pump gear, at least on mine, stayed in the engine. Take care not to turn the engine while the pump's off and it should all go back together easily enough. It's been a couple years since I did mine so the details might be off a bit, but the main point is that there are marks from the factory that'll let everything be back in time when you put her back together as long as all the marks are lined up like they were before. Mine started right up once everything was bled out- hope your luck is as good!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
