Re: Farmall H won't start
Posted by El Toro on October 19, 2005 at 15:56:09 from (64.12.117.13):
In Reply to: Farmall H won't start posted by Retcol on October 19, 2005 at 15:02:45:
You need to check the wire from your ignition switch back the starter solenoid. You may have a broken wire, bad connection or a bad switch. You should have voltage at the solenoid. Remove your ground cable and remove the battery cable at the starter solenoid and check for corrosion. Clean this connection nice and shiny, then reconnect & hook up ground cable. There should be voltage on one the small terminals at the solenoid. Use a volt meter, if voltage is present you need to trace that wire to your switch and check for voltage there. No voltage present, wire could be broken. If there's voltage use a jumper wire to jump around the switch to see if lights work or if engine will crank. If it does switch needs to be replaced. Hal
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
