Re: How to tell if generator 6V or 12V?
Posted by John T on October 19, 2005 at 16:39:02 from (66.244.90.98):
In Reply to: How to tell if generator 6V or 12V? posted by Farmall B on October 19, 2005 at 15:44:17:
Farmall, What voltage do you want it to be??? I have used 6 volt Generators to charge 12 volts SIMPLY by using a full fledged 3 terminal 12 volt Voltage Regulator (instead of a 2 wire cutout relay and light switch controller) on them. HOWEVER Im NOT saying thats the correct way to do it, Im JUST SAYING Ive done it n it worked. The better n correct way would be to have a good Generator shop rebuild it as a 12 volt by replacing the fields etc.
John T
Post a Followup
