Re: 100 oil pump
Posted by El Toro on October 20, 2005 at 03:50:43 from (64.12.117.13):
In Reply to: 100 oil pump posted by Robert in MS on October 18, 2005 at 14:39:49:
I would check the body of the pump to make sure
the gears haven't been rubbing & wearing away the metal. I would replace those gears too if they're available. Be sure to set the pump in a
clean container of oil and twist the pump shaft so the pump is primed. That pump is probably
the same as used on the tractors with the C-113 & C-123 engines. Hal
Post a Followup
