Re: Engine Knock
Posted by Janicholson on October 20, 2005 at 14:40:44 from (199.17.6.175):
In Reply to: Re: Engine Knock posted by PR Pete on October 20, 2005 at 13:45:12:
There are as many solutions as mechanics. The water deluge is at least benign to the neighbors, putting a cup of ATF in the intake in a thin stream isn't so kind. Tractors often run at 50% power or more. Old leaded gasoline leaves deposits good enough for bank of america. New gasoline with injector cleaners and far less chemical (metalic) additives is likely to clean deposits off of surfaces, at least it lets them decay instead of building up. If your tactor is putting around doing very little, I'd put a load on it for an hour or three doing real work just to ("Blow" it out). JimN
JimN
Post a Followup
