Re: How to remove the oil guage
Posted by Bob M on October 21, 2005 at 07:26:36 from (151.190.254.107):
In Reply to: How to remove the oil guage posted by fenton on October 21, 2005 at 06:12:42:
My experience is mechanical oil gages will fail either of two ways: 1 – They indicate HIGHER pressure than actual (and usually the gage hand does not return to 0 when shut down) . 2 – They fail to indicate at all (accompanied usually with the gage face filling up with oil). I have never encountered one that reads lower than actual, though I suppose it is possible. Gage replacement is simple – just unscrew the old one and screw in the new. Like Hal says there should be a square wrench flat on the nipple to turn it with. (Don’t turn it by grabbing the OD of the gage with big pliers or a pipe wrench – you may regret it later!) Tip: Before installing the new gage check it against a known accurate gage using air pressure. I’ve found that gages from Tisco, AutoZone, etc. generally don’t begin move move off “0” until the actual pressure is about 5 – 7 psi. And they read lower than actual until pressure reaches about 20 psi actual. --- Low oil pressure can be caused by several things – and usually is a combination of things. Could be as simple as sludge clogging up the pump suction screen. (Not uncommon when non-detergent oil has been used for many years). Oil pump wear is another. But most often the cause is worn main, rod and cam bearings. I’d first drop the pan to and clean the pump screen and bottom of the pan (an easy job – all you need is new pan gasket). Sometimes you’ll find the oil pump gasket gets partially blown out or the pump cover is slightly warped. Again not a difficult job to disassemble and replace the pump gasket once the pan’s off. Bearings get a little more complicated. Mains and rod bearings can be replaced from below after dropping the pan. Cam bearings however require disassembly of the engine. One other “fix” that works for lightly used (i.e. show and parade) tractors with low oil pressure: Change to 15W-40 oil. It flows easily enough for good cold starting, yet it’s high temperature viscosity helps maintain higher oil pressures when warm.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
