Re: 1949 Farmall Cub transmission
Posted by George Willer on October 23, 2005 at 13:27:44 from (208.252.179.21):
In Reply to: 1949 Farmall Cub transmission posted by George the farmer on October 23, 2005 at 12:29:21:
George,
Yes, there's a seal there. Check first before you split the tractor (at the transmission), because the problem may be simple overfilling. Do this: remove the level plug low on the left side of the transmission. If oil comes out, it may be overfull due to accumulated water. In that case, you know what to do. Then park the tractor with the front low so old accumulated oil can drain from the torque tube. Only then should you worry about replacing the seal.
George Willer
Post a Followup
