Re: Serail no. on 460 Diesel?
Posted by Jimmy King on October 23, 2005 at 15:47:36 from (4.244.48.78):
In Reply to: Serail no. on 460 Diesel? posted by migraine on October 23, 2005 at 14:47:52:
well the # makes it a 1959, that is what mine is. I never can remember what all the letters mean . The engine will be a 236CID, it could have TA, Live PTO, fast hitch, and live hyd. Live pto and HYD are standard. I have owned mine since the middle 70's, and used it hard pulling haybine, round baler, seven ft. roam offset plow. The 236 is a very eficent engine, I could pull a left and right N H hayrake all day on 1/2 gal an hr the Roam on 2 1/4 gal per hr. The only difference on this engine. and the 282 is the stroke. the 460 is rated 52HP, I had mine on a Dino once and it turned 63 HP.
Post a Followup
