Re: Crankshaft Pully
Posted by El Toro on October 23, 2005 at 16:45:05 from (205.188.117.73):
In Reply to: Crankshaft Pully posted by Gene37 on October 23, 2005 at 15:48:08:
There may be a cap screw in the center or a set screw. It may not have anything except the press fit on the crankshaft. You should use a split bearing separator behind the pulley to pull from. You can make a puller like this that was designed for the Cub pulley and use a hydraulic
jack. I would still use the separator too. Here's the web site for the puller. Hal
http://www.ytmag.com//farmall/messages/459316.html
Post a Followup
