Re: M Farmall fan belt
Posted by MagMan on October 23, 2005 at 17:58:06 from (205.188.117.73):
In Reply to: M Farmall fan belt posted by K Smith on October 23, 2005 at 16:36:55:
I tryed the impact screwdriver on my H yesterday and it broke the screw off at the top but I was able to heat it up and get it loosewith the trusty vise grips. Be carefull I also heated the ring that is under it that turns to tighten it and taped it and it cracked. So I found replacements through AI for thirty bucks.
So after you get the screw out you need to turn the outer part of the pulley and it moves the belt up and down the pulley to tighten and loosen it make sure you get the set screw tight after wards or it will tighten on its own when running and give you a problem
JON
Post a Followup
