Re: seat shock bolt 49 M
Posted by Randy in NE on October 25, 2005 at 04:06:39 from (204.124.192.90):
In Reply to: seat shock bolt 49 M posted by Bob Underwood on October 25, 2005 at 03:38:03:
For tractors F-501 to F-28174 and L-500001 to L-504801 there is not a shock absorber. Different design. For F-28175 Up and L-504802 to L-512541 it is part number 351750R93. You will need four of the rubber grommets. For the "Hydraulics Seat (Special)" it is 353204R93 and you will need two rubber grommets. 351750R93 has a loop on each end of the shock absorber and has a rod with two of the rubber grommets on each end. 353204R93 the shock absorber has a loop on one end with the rod and rubber grommets. On the other end it has a threaded shaft sticking straight out the end with two different shaped rubber grommets, more like the shocks on the front of a car.
Post a Followup
