Re: C 153 oil pump
Posted by El Toro on October 25, 2005 at 05:01:54 from (152.163.101.13):
In Reply to: C 153 oil pump posted by Catskill Pete on October 24, 2005 at 13:51:38:
If there were any metal particles in that oil pan
there's probably more metal in the oil passages
on that engine. The engine should be torn down and the block completely cleaned if the pan had metal particles because you're going to circulate
all that through the engine again once you start using the tractor. Hal
Post a Followup
