Re: Help to identify IH 300 hydraulic pump
Posted by Dellbertt on October 25, 2005 at 11:30:28 from (204.39.210.85):
In Reply to: Re: Help to identify IH 300 hydraulic pump posted by Bruce Runyard on October 25, 2005 at 11:16:30:
Nope it all comes out easy and in one piece. If you have aluminum case that is worn too much it is best to have it machined and rebuilt. A rbuilt one costs about $500-$700. If yours was pumping ok and just mixing with crankcase oil I would not open the case but just install new shaft oil seal.
You did not mention if you had a Front Power take-off. If you do the pump is completely different and the seal no. 552 102 R91.
Your dealer should be able to give you a parts pictorial to show you how the thing is put together. The Pesco and the Thompson have very similar cases with the pump no. on the upper outside of the case. If you can"t get a pictorial from your dealer I will try to send you one.
Post a Followup
